Hi Tony
Does Sable have the equivalent of the two reset buttons that Vensim has in synthesim mode? One is the 'rest current slider to base model val (Home)' and the other is the 'reset all constants/lookups to base model vals (Ctrl+Home)'
David
Reset in Synthesim
Moderator: Administrator
Re: Reset in Synthesim
Hi Tony
Did you get a response to this one? I am interested, as not having that facility does make it more difficult for clients to use the models. When they've changed a value they have no way of knowing, in the interface, what the original or baseline value was. I'm trying to make my models as easy as possible for clients to use and this would facilitate that enormously. Currently, I simply put in a text statement by the slider showing the baseline value, which is a bit clunky although it does work
Cheers
David
Cheers
David
Try
I may need to update the underlying Vensim engine, but it should work.
SYNTHESIM>RESET
Hi Tony - works great! Thanks once again.
David
David
