Count if
flo
Count if
Post by flo »
Hey there,
I'm using Vensim DSS and what I try to do is to create (or use an existing?) function that works he way the "COUNT IF"-Command in IBM SPSS or MS Excel does. The model is connected to database and i want to count the number of certain values in the database list (for example COUNT IF VALUE=7). Is that somehow possible?
Thanks a lot!
Re: Count if
You will need to use something like
sum ( if then else ( value[range!] = 7 , 1 , 0 ) )
Re: Count if
It's not entirely clear what you're counting, but GET DATA TOTAL POINTS might also be useful.
flo
Re: Count if
Post by flo »
The function sum ( if then else ( value[range!] = 7 , 1 , 0 ) ) works perfectly, thanks a lot.
