sable stopped working
Moderator: Administrator
kai wang
Post by kai wang »
Hi Tony,
Everytime when I tried to add a graph, sabel just stopped working. Can you please give me some help. Thank you!
Re: sable stopped working
What version of Sable are you using?
And do you get a graph appearing on the screen at all, or does it crash immediately?
kai wang
Post by kai wang »
Thanks for your reply. My Sabel version is 5.1.468.0.
I can add a graph on the screen, but when I try to edit it (open its properties), Sable just stopped working.
I can view the properties ok. Are you selecting a certain property or tab?
kai wang
Post by kai wang »
Administrator wrote:I can view the properties ok. Are you selecting a certain property or tab?
I can even not choose any property or tab. When I right click the graph and choose property then it died.I attached my model, would you please take a look?
IDT model.rar
model of Kai Wang
(127.36 KiB) Downloaded 1937 times
Everything seems fine to me.
Can you explain exactly what you are doing step by step? I mean what buttons you press etc and I'll take the same steps here to try and recreate the problem.
When you insert the graph, do you see a blank graph at all? Or just a hollow box?
kai wang
Post by kai wang »
Administrator wrote:Everything seems fine to me.
When you open the model, go to the screen of "Result summary_ water resources.VNN". Click on the "graph" button, then a new window get out asking me "New graph type?", I choose "Yes". After that, click on the screen to add a graph, then a hollow box appear on the screen. Right click on this hollow screen and choose "Properties", then Sabel died.
I attached a picture of the problem. Thank you.
Sable stop working.png (50.86 KiB) Viewed 38841 times
ok, it looks like the graph component has not installed properly (the hollow window should show something).
Can you try reinstalling?
kai wang
Post by kai wang »
Administrator wrote:ok, it looks like the graph component has not installed properly (the hollow window should show something).
Hi Tony,
Thanks for your kindly help. I reinstalled Sabel and it worked. Thanks again.
Kai
