Hi folks,
I am running Windows 7 (64 bit) and I am unable to run any Vensim models or manipulate them. Everything I open is "locked sketch" and the error reads that I can only use the system in sketch view..
Does anyone have any ideas on if and how I can evaluate this system?
Cheers,
Mike
Vensim PLE and 64 bit Windows
Re: Vensim PLE and 64 bit Windows
Can you post one of the offending models?
I rather doubt that the operating system has anything to do with it, because loads of people are running Vensim in 64bit environments.
Do the models you're trying to use originate in PLE, or some higher version? Can you open & run them with the Model Reader?
