how to turn of WARNINGS ?
diajeng permata
Post by diajeng permata »
dear vensim,
i got warnings "lookup out of bound above 9" but that is what i wanted, because i just wanna lookup until time 9 and then random the rest.
so is there any way to turn of the warning window so there will eliminate activity of closing the warning window everytime I run the sim?
thanks for advance.
Re: how to turn of WARNINGS ?
Tools->Options->Settings->Warnings, select "Suppress" and they will no longer be displayed.
diajeng permata
thank you very much
diajeng permata
i'm sorry,but i can not find setting--> warnings.
is it available in vensim PLE?
I've just checked, it's not available in PLE.
You could modify the equation to suppress the error. Two possibilities:
1. Add an extra point to the lookup, at FINAL TIME or beyond. It won't get used, but will prevent running out of bounds.
2. use MIN(Time, 9) rather than Time as the input to the lookup. You probably also want to make the "9" a parameter so that it's visible and has units.
