Hello
I had a subscript called TECH: hs, rr, nuc
Then i created another subscript (PDC) taking all the elements from 'TECH' and added a new one (lti), i.e., PDC: hs, rr, nuc, lti
When I run the model, i get this error: "All arrays must have same size last element for REORDER"
Before creating the subscript 'PDC', the model run perfectly.
Does anyone know what is happening?
Adding a subscript using elements of other subscript
Re: Adding a subscript using elements of other subscript
Are you using a VECTOR REORDER with PDC on the LHS and Tech on the RHS of the equation?
Hard to tell without seeing the equations in question.
I did not even used the subscript 'PDC'. I just created it and I got this error
A function you've used may be expecting a complete range rather than a subrange, and the addition of the new subscript converts TECH to a subrange. Hard to tell without an example though.
In the following example i have a subscript tech:(p1,p3) and all the equations use tech
Then, i created the subscript 'pdc': tech, p4
If you remove it, the model works again
See the file I attach
Thank you
Thank you
- subscripts and subranges.mdl
- (11.5 KiB) Downloaded 193 times
It seems that VECTOR REORDER does not work with subranges... I can create a new vector PCD: hs1,rr1,nuc1,lti1 and then create a subrange let's say PDCsub: hs1,rr1,nuc1->Tech, in case i need to do some calculation with both. Do you have another suggestion?
P.s. You might add the use of subranges in this kind of function as a possible improvement
It may work with subranges (I don't recall), but I think that's not quite the issue. You have several instances of mixed subscript uses - for example:
vector reorder(Desired expansion x hour[HOUR,EXPN2],price order inc[HOUR,TECH])
I think it's checking the size of the TECH family (=PDC) against EXPN2, and reporting the error because this is 4 vs. 3. This could be overzealous checking - I'll have to look at the code.
I'm surprised that it worked before, because you don't have TECH mapped to EXPN2.
