I could open two or more Vensim models in Windows 7, but cannot do that in Windows 8. Any suggestion!?
Thanks,
Junaid
Opening multiple Vensim models at the same time (Wondows 8)
Re: Opening multiple Vensim models at the same time (Wondows
Click Tools->Options->Settings, the untick "Close active model on Open/New".
That should fix it.
That should fix it.
That's useful, Thanks Tony. Is it also possible to open two or more models at the same time so that I can run them simultaneously?
No, Vensim will not let you run them at the same time.
What are you trying to do?
You can open two instances of the application and run independently in those, but they won't have any connection.
Yes, that is my question. How to open two instances of Vensim at the same time?
Just click the Vensim icon twice.
