Load run order
drw
Load run order
Post by drw »
Since upgrading to version 6.3 of Venism DSS (x32), when running a new simulation the result appears to be last in the order rather than first (as in previous versions). I know you can go into the control panel and manually change this, but is there a system setting one can set to ensure that new runs always appear first (i.e the first line of data when showing a table, or the blue line in a graph).
Dave
Re: Load run order
Click Tools->Options->Settings and then change the "Load datasets in position" option.
drw
Re: Load run order
Post by drw »
Thanks for the fast response. The current setting was set to "first" dataset already. I tried changing it to "2" and to "last" and in both instances it always loads as the last dataset. In other words, it appears to always load as the last dataset regardless of this setting for new runs. I have checked with several of my colleagues who use Vensim (same version) and they all experience the same problem. Is this potentially a bug which has been introduced?
Note: Realised that this "dataset setting" works when loading new runs in Control Panel -> Datasets. However, setting makes no difference when you perform a new run (i.e. defaults to last).
Dave
Re: Load run order
I thought this bug was fixed. I'll check it out.
Re: Load run order
This is fixed in 6.3D.
drw
Re: Load run order
Post by drw »
Thanks for your help. Finally got the latest version installed on my PC and can confirm it has been indeed fixed.
Dave
