Hi there,
I'm using Vensim 7.2 Pro, and trying to export the simulation results of sensitivity simulation.
The window of "Sensitivity run export" has a check box of "export percentiles" at the bottom.
I expected the output file contains percentile information by checking this box.
However, the output is the same as the file without the check.
(I used diff command of Windows to compare files.)
Does this check box work?
Unfortunately, manual (local and WWW) doesn't contain related information; the page of "exporting sensitivity results" in the reference guide has older version's information only.
Best,
Yut.
exporting sensitivity test data
Re: exporting sensitivity test data
This is a bug which will be fixed in the next release.
Unfortunately there is no workaround in Vensim Pro.
I see. Thanks for the information.
