is it possible to partially export data from Vensim to excel?
I don't want to export all the results for all subscripts (the whole range), only the results for certain subscripts.
I'm using Vensim Pro 7.3.5.
Hope somebody can help me
Julian
exporting dataset
Re: exporting dataset
Yes. When you are exporting the dataset, there is a field for "Savelist". This is just a text file containing a list of the parameters you wish to export.
To use, click the savelist button and you will be prompted to enter a filename. Now click the "Ed" button, this will let you select what you want.
Ah perfect, thank you! I must have overlooked it somehow.
