sensitivity analysis (vensim)
RWTH_FCN
Re: sensitivity analysis (vensim)
Post by RWTH_FCN »
I ran the model on a super computer but since this version does not do any parallel multicore computation, the running time did not reduce. Do you have any plan for releasing that experimental version?
We're working on it, but I'm not sure whether it'll be done by end of year. The speedup is more than noticeable if you have a many-core machine. Older workstations with 16 or more cores are now readily available at dirt cheap prices. We'll keep you posted as this evolves.
RWTH_FCN
Post by RWTH_FCN »
tomfid wrote:
Mon Oct 14, 2019 5:24 pm
Thanks for your information.
RWTH_FCN
Post by RWTH_FCN »
I did Monte carlo Simulation for a large-scale model, after many simplifications in my model I got this error (it happens at Sensitivity Simulation 1/3):
error writing results-disk may be full
I was wondering is there any solution for it or is it related to size of model?
Any chance that the disk really is full (or would be, after writing the results)?
RWTH_FCN
Post by RWTH_FCN »
tomfid wrote:
Mon Oct 28, 2019 5:44 pm
I don't think so. Maybe it is related to the size of model
Are you using 32 or 64 bit Vensim? If you do a run with only 1 sensitivity instance (if you can), how big is the file size increment over a non-sensitivity vdf file?
Actually, I see that the error happens on sim 1. Looking at the code, the counter for writing sensitivity result blocks is an integer, which will impose a 2 gigabyte limit per simulation. Any chance you're near that?
RWTH_FCN
Post by RWTH_FCN »
tomfid wrote:
Tue Oct 29, 2019 7:09 pm
I am using 32 bit now. The problem occures when I increase number of iterations. I think your assumption is correct, when size of vdf reaches 2 Gb it produces that error.
Can you increase the SAVEPER or thin out the savelist a bit? If you're getting gigabytes of output from a one or two simulations, it'll be pretty unwieldy when there are many.
RWTH_FCN
Post by RWTH_FCN »
tomfid wrote:
Tue Nov 05, 2019 3:50 pm
Sorry for late response. Actually, I used increased version of SAVEPER. For my case, as long as the model is huge (simulation of compiled version takes around 20 minutes) implementing Monte carlo and stochastic optimization is a big deal in Vensim.
