I have run model several times and since dataset are huge I want to delete them. To do so, I should go in Windows->Control panel->Datasets. The problem is that I can not delet them and they stay here. Do you have any ideas why it heppens?
Question about deleting previous runs
Re: Question about deleting previous runs
What version of Vensim are you using?
You can always delete them manually as well by browsing to the folder where they are stored.
Version 6.4. Actually, when I want to delete them manually I get an error that they cannot be deleted becasue file is open in Vensim. So, I decided to remove them in Vensim but it is not possible in Vensim as well.Administrator wrote: ↑Fri Mar 06, 2020 10:15 am What version of Vensim are you using?
If you close Vensim, you will be able to delete them manually.
Ah, you are right. thanksAdministrator wrote: ↑Fri Mar 06, 2020 10:37 am If you close Vensim, you will be able to delete them manually.
