I'm trying to optimise my model but the simulation run get stuck into the notification ""setting up the simulation" with no run.
I have attached the model here.
Could you please help me with the issue?
Notification "Setting up the simulation"
- Vensim version: PRO
- Setting up the simulation .zip
- (9.75 KiB) Downloaded 156 times
Re: Notification "Setting up the simulation"
You are getting into problems as there is an error in your model. Run it (not optimize) and then look at the graph for "Bev Scientific Knowledge Development Stock". Is that correct?
Thanks very much.Administrator wrote: ↑Fri Apr 10, 2020 1:50 pm You are getting into problems as there is an error in your model. Run it (not optimize) and then look at the graph for "Bev Scientific Knowledge Development Stock". Is that correct?
Yes you are right!
