Getting the y-axis value
Hello community
There is one (i hope) simple question from me.
I have an auxiliary ouput and i would like to use the y-axis value of the output into my next step of modelling.
I thought i can use GET DATA AT TIME function, but it seems like it can only be use for data variable.
Can anyone help me?
Thanks in advance
Can anyone help me?
Thanks in advance
Re: Getting the y-axis value
You can use SAMPLE IF TRUE or a stock to store the value of a variable at a particular time.
You can't access values in the future.
Hi Tom,
I couldn't find way to use the SAMPLE IF TRUE function to continue with my model.
Attached is the example of sub-model that i'm working on now. I want to trace the value of the marginal cost (RM/MWh) at each T, which i named it as component 1 - component 4.
The T1-T4 variables is taken from the date i import from excel. Why i did this is because Vensim didn't permit the x-axis to be any other than time. So, i'm making a long way to get to the value that i want. I hope u get what i'm trying to say.
Really hope that u can help me once again. Thanks in advance, Tom
- Cummulative MWnew.xls
- (22.5 KiB) Downloaded 151 times
- test.mdl
- (9.69 KiB) Downloaded 172 times
Last edited by husnafezaahmad on Fri Aug 28, 2020 5:09 pm, edited 1 time in total.
I don't think I understand what this is trying to do. Is T time, or a time segment, like base/mid/peak? Or is it the time at which a given capacity level is reached?
Either way, the condition in your SAMPLE equation is dimensionally inconsistent - you have Marginal Cost Curve=T1, but T1 is in years and Marginal Cost Curve is in RM/MWH. Maybe this is the issue?
Oh my god, i forgot to change the unit. The unit should follow.tomfid wrote: ↑Fri Aug 28, 2020 5:03 pm I don't think I understand what this is trying to do. Is T time, or a time segment, like base/mid/peak? Or is it the time at which a given capacity level is reached?
Anyway, i've the same model with the same idea. Attached is it.
But in this Pool Market model, i got my marginal cost from imported excel data.
But this time around, my marginal cost isn't from excel file. Did u get what i mean?
I'm so sorry, i'm so bad in explaining.
- Pool Market (Base).mdl
- (47.21 KiB) Downloaded 168 times
Sorry, i forgot to attach the excel files.
- MarginalCostNew.xls
- (22.5 KiB) Downloaded 142 times
- (22.5 KiB) Downloaded 145 times
Don't worry, we'll get there.
I'm still not sure what T and components 1..4 represent though.
Thanks Tom
So, in "test.mdl", i used T1-T4 as the variable that will find the value of X-axis at MW1-MW4 according to accummulative MW graph.
And this value will then be used in component1..4, in order for me to get the y-value axis in marginal cost's graph.
For example;
in my accumulative MW graph, i have
MW1 = 8323 MW
Then in T1, i would like to know at which year does MW1 appears.
Let say, 8323MW appears at year 9.17.
Again, i want to know in marginal cost graph, at year 9.17, what is the value of marginal cost.
Did i make myself clearer?
I hope i can get some enlightment to solve my problem
Ok ... I think I understand what the cost curve is doing. But why go to all the trouble of constructing the curve, when you can simply observe the marginal cost at time 9.17 directly?
How can i do that, Tom?
I mean, i am totally lost at the moment. I tried IF THEN ELSE but idk, it didn't turn out as what i expect.
I also tried SAMPLE IF TRUE, and the result is the same.
I'm still hoping that i can get some enlighten bout my problem
You could use something like
sampled marginal cost = SAMPLE IF TRUE( Time<=desired time, marginal cost, marginal cost )
desired time = 9.17
At or after time 9.17, this will show the marginal cost at time 9.17.
However, I'm still not clear on how this is being used, so this may not be useful.
desired time = 9.17
