Need help for fixing syntax error
alvinpoon
Post by alvinpoon »
I get 2 MDL files from SDR supplementary (see attached) that I cannot open it.
It shows the text view, and I can't switch to the sketch view as it promts syntax error, I appreicate someone who know how to solve this and advise?
Thanks a lot.
rework.mdl
(109.1 KiB) Downloaded 156 times
Supply Constraints Model SDR Final.mdl
(80.54 KiB) Downloaded 150 times
Re: Need help for fixing syntax error
Any chance that these files were opened into a browser window, then saved with a Save As... ?
The problem is that a bunch of invalid line breaks in variable names have been inserted into the text. For example:
Current Normal Development Capacity = Normal Engineer
Capacity*(1-step(1,Methodology Intro Date\
+Engineering Capacity Under New Methodology*step(1,Methodology Intro Date)
	~	tasks/Month
	~	Maximum Development Capacity if Organization Follows
Methodology
Normal Engineer<cr/lf>Capacity should be Normal Engineer Capacity with a space instead of a line break. I think Vensim didn't insert these breaks, because it uses \ for line breaks, and doesn't break variable names.
This could be fixed, but it might be a lot of manual labor. It would be much easier if you could get an uncorrupted version of the files. Using Save Link As ... often works where text retrieval won't.
