Hello everyone:
I want to use MFC programming to call Vensim model, but I have encountered some problems. Please help me with some problems.
1. In the example in the subdirectory DLL / msvc60 under the Vensim installation directory, use visual_ SDUDIO_ Can 2010 software be recompiled?
2. Vensim dssx64 is installed, and the compiled time prompt cannot find vendll32.dll.
3. Can I use visual in the environment of installing Vensim dssx64_ SDUDIO_ Does 2010 program call the actual use case of Vensim model?
Re: MFC programming to call Vensim model
Hello everyone:
1. In the example in the subdirectory DLL / msvc60 under the Vensim installation directory, Can I use visual_ SDUDIO_2010 software be recompiled?
3. Can You use VISIOL_ SDUDIO_2010 in the environment of installing Vensim DSSx64 to program and provide an Example?
thanks much!
thanks much!
Yes, you can use Visual Studio 2010.gongyongfu wrote: ↑Wed Jun 09, 2021 6:19 am 1. In the example in the subdirectory DLL / msvc60 under the Vensim installation directory, Can I use visual_ SDUDIO_2010 software be recompiled?
Change this to vendll64.dll.gongyongfu wrote: ↑Wed Jun 09, 2021 6:19 am 2. Vensim dssx64 is installed, and the compiled time prompt cannot find vendll32.dll.
The samples that are provided with Vensim should work with Visual Studio 2010.gongyongfu wrote: ↑Wed Jun 09, 2021 6:19 am 3. Can You use VISIOL_ SDUDIO_2010 in the environment of installing Vensim DSSx64 to program and provide an Example?
thanks much!
First of all, thank you for your reply, There are still problems:
After running VenMFC.exe directly in the subdirectory of “Users\Public\Vensim\DLL\msvc60”, a message appears: "since VENDLL32.dll cannot be found, the code cannot be executed. Reinstalling the program may fix this problem“
Run VenMFC.dsw in the subdirectory of “Users\Public\Vensim\DLL\msvc60”, and select "yes" in the dialog box to start “Execution (Without Debugging)”. The following information appears:
1>ClCompile:
1> VenMFCDlg.cpp
1> _ WIN32_ WINNT not defined. Defaulting to _ WIN32_ WINNT_ MAXVER (see WinSDKVer.h)
1>c:\users\public\vensim\dll\msvc60\venmfcdlg.cpp(304): warning C4996: 'sprintf': This function or variable may be unsafe. Consider using sprintf_ s instead. To disable deprecation, use _ CRT_ SECURE_ NO_ WARNINGS. See online help for details.
1> C: program files (x86) Microsoft Visual Studio 10.0, VC, include, studio. H (371): see the statement of "sprintf"
1>c:\users\public\vensim\dll\msvc60\venmfcdlg.cpp(321): warning C4996: 'sprintf': This function or variable may be unsafe. Consider using sprintf_ s instead. To disable deprecation, use _ CRT_ SECURE_ NO_ WARNINGS. See online help for details.
1>c:\users\public\vensim\dll\msvc60\venmfcdlg.cpp(361): error C2660: “vensim_ synthesim_ Vals ": the function takes three arguments
1> VenMFC.cpp
1>c:\users\public\vensim\dll\msvc60\venmfc.cpp(52): warning C4996: 'CWinApp::Enable3dControlsStatic': CWinApp::Enable3dControlsStatic is no longer needed. You should remove this call.
1> C: program files (x86) Microsoft Visual Studio 10.0, VC, atlmfc, include, afxwin. H (5347): see the statement of "cwinapp:: enable3dcontrolsstatic"
1> StdAfx.cpp
1> Generating code
1>
1> Build failed
1>
1> Time used 00:00:08.23
==========Generated successfully 0, failed 1, latest 0, skip 0==========
In this case, What should I do?
1>ClCompile:
1> VenMFCDlg.cpp
1> VenMFC.cpp
1> StdAfx.cpp
1> Generating code
1>
1> Build failed
1>
Change your code to load "vendll64.dll" instead of "vendll32.dll".
Also ensure that you are building a 64 bit application.
