Sensitivity Data
- Vensim version: PLE+
Sensitivity Data
I am running a sensitivity analysis with PLE Pluse. I am trying to export the variable data (input and output) for each scenario. For example, I have four input variables that vary randomly from 1-10. I am tracking two output variables. I want to export each multivariate combination and the corresponding outputs for 200 simulations.
I am able to export the output variables, but I can't figure out how to get the corresponding multivariate combinations.
Thanks in advance for your help
Re: Sensitivity Data
Do you have the variables in the save list that you want to export?
Thanks for your reply. Yes. All four input variables are in the Savelist.
Do you have a sample, or can you .zip up the model and supporting files?
The default export should include both the output variables and the input parameters from the .vsc file.
Here is the model. Thanks for giving it a look. If you run the Sensitivity function all of the variables are already selected.
- I4.0_Ship Repair_S&F_02152021F-5_Experiment Data.zip
- (8.24 KiB) Downloaded 181 times
The .zip seems to be missing the .vsc and .lst files?
Sorry about that. Attached are:
1) I4.0_5.0_Experiments.vsc
2) TechFactorExperiment_Input_Output.lst
3) I4.0_Ship Repair_S&F_02152021F-5_Experiment Data.mdl
- I4.0_Ship Repair_S&F_02152021F-5_Experiment Files.zip
- (8.74 KiB) Downloaded 186 times
One problem is that you have a colon in your run name. Colons are illegal file system characters, so that breaks naming the dataset. We'll have to disallow those and a few other characters I guess.
After deleting the colon, I can run and export the sensitivity results to yield:
Simulation Tech Factor: Adj Time for Efficiency Impact"" Tech Factor: Cost"" Tech Factor: Efficiency Fractional Rate"" Tech Factor: New Business"" Port City Jobs ROI
1 2.135618875 1.12322795 7.044533483 4.612675317 115320.5959 100
2 14.34797783 2.626708798 1.8172899 7.52753672 700102.7978 99.4391724
3 8.60677939 4.772745214 2.285229625 4.54597021 193676.7468 99.77060124
4 15.94191306 6.040241197 8.737766876 6.943789773 236468.1576 99.04659886
How do you create that report? That looks like exactly what I am trying to do!
I think I have it! Under the Model tab, Export Dataset. Thank you very much for your assistance. I really appreciate it.
v/r,
john
v/r,
john
Sorry - should have mentioned that explicitly! Glad it's working. We're hoping to roll some capability for visualizing this into native Vensim soon.
