Hi there!
I am using PLE+ and I wanted to know that when we run the sensitivity test is there any way to save the numerical results of confidence bounds?
Thank you
save confidence bounds result
Re: save confidence bounds result
the only data that I can export from the sensitivity analysis is the lower bound of 50% confidence, is it not possible I export other data?...
Because if I want to make a comparison of this result with the current results, it doesn't make sense!
any suggestions?
any suggestions?
I'm not sure what you mean here. I just exported the following from a PLE+ run, using Model>Export Dataset, using the Export Final Time and Percentiles options:
Are you looking for something different?
Percentile time to adjust workforce time to correct inventory Inventory Workforce net hire rate production sales target inventory target production target workforce
0 1.052374936 1.011997316 449.8410237 149.9267669 -0.051913851 149.9267669 150 450 149.6846847 149.6846847
1 1.054767978 1.032828921 449.8636509 149.9440972 -0.050329368 149.9440972 150 450 149.8047032 149.8047032
2.5 1.123183231 1.104980973 449.8875807 149.9743255 -0.006612583 149.9743255 150 450 149.9652864 149.9652864
5 1.208182464 1.170991261 449.9323002 149.9811199 -0.003783228 149.9811199 150 450 149.9781852 149.9781852
10 1.449884315 1.306583602 449.9681656 149.9956928 -0.001992897 149.9956928 150 450 149.9940502 149.9940502
25 1.822710868 1.944630453 449.9996658 149.9999447 -2.55E-05 149.9999447 150 450 149.9996614 149.9996614
50 2.850245057 2.90362486 450 150 3.87E-13 150 150 450 150 150
75 3.960943092 3.934144443 450.0009227 150.0001042 4.33E-05 150.0001042 150 450 150.0001152 150.0001152
90 4.579610808 4.572570215 450.0170364 150.0063823 0.002550794 150.0063823 150 450 150.0095027 150.0095027
95 4.744871022 4.805377082 450.0497866 150.0175383 0.004233795 150.0175383 150 450 150.0229895 150.0229895
97.5 4.80995824 4.8879636 450.0864176 150.0341611 0.006902274 150.0341611 150 450 150.0418547 150.0418547
99 4.949281685 4.93988307 450.1392669 150.0460247 0.009046833 150.0460247 150 450 150.0564186 150.0564186
100 4.962008311 4.986298 450.3271499 150.0747628 0.018058793 150.0747628 150 450 150.0671816 150.0671816
