I suddenly got problems with runs when using my new DSS version:
1- I'm always asked for a flie name whilst in my previous PLE vertsion this name was directly available when running Synthesim
2- The initial values specified are not reflected in the stock results
3- I have to wait quit some time when running Synthesim because the system is checking eqiuations - in the PLE there was no checking at all and I could run Synthesim directly
Something is goingwrong here with my new DSS license. Can you help me out?
Problems with initial values and starting runs
Re: Problems with initial values and starting runs
It's the number of points on the x axis that Vensim is struggling with.
You could change the value of SAVEPER, this will make things much better.
Increasing Saveper helped for response time.Thank. However I still have the problem with the initial values. See for instance the stock WACHTRIJ VERWIJZING PHOZ (the first yellow colored stock; top left) The initial stock should be 5000 butvthe graph shows 0. Looking into the equation the initial value is correctly entered.
Problem solved. My mistake. Sorry
