I have a model with two subscripts, Type and Object. Then I have a subscripted constant TypeValue[Type] and a subscripted constant ObjectType[Object]. The values in ObjectType shows back to the index of Typevalue. How can I fill up the auxiliary ObjectValue[Object] with values from TypeValue based on the index in ObjectType[Object]?
Model attached (db1.mdl)
Morten
Subscripts..
Morten,
this is the way I do it (see attached model). If there is anyone out there with a more elegant method, then please post it here!
- subscripts1.mdl
- (1.98 KiB) Downloaded 652 times
