I realise this is a basic question -- I did look in help and search the forum, but I'm probably missing something obvious.
I'm using Vensim DSS 8.0.9.
I need to present a CLD loop by loop, inserting snips into a presentation. I would like to take the final CLD and delete some variables and links, so that I have a set of files showing the loops one by one.
When I delete variables and loops, I want the display to *not* expand to fit the screen, i.e. a loop that occupies the bottom right corner of the view should stay there, leaving white space where I deleted other elements. How do I do this?
Screen display
Re: Screen display
Is Zoom->View->Fit to screen set?
Re: Screen display
Setting the zoom to a fixed level should solve this.
Also, you may want to hide variables rather than deleting them. That way you can do everything in one model, and even one view.
Re: Screen display
Agree that a Hiding variable is the way to go when doing this.
Is there a still a way, with the new drawing system, to export a view as a vector image that can be edited easily in PPT (for transitions) or another image editor?
Re: Screen display
Thank you! I realise now it is much easier to just hide elements. Strangely, setting the zoom to a fixed % does not work.
