Vensim PLE equation tool bug
Starting yesterday I encountered an issue when using Vensim PLE when I use the Equation function to edit equations for variables, there was no close button, and the whole system froze. I had to force quit the software. I attached a screenshot so that you can see the bottom line of the equation window is missing. Is there any solution? Thank you!
Re: Vensim PLE equation tool bug
Have you tried resizing the editor?
Also, what version of MacOS are you running?
What version of Vensim?
May I ask how to resize the editor? I am using macOS 13.4.1 and Vensim PLE 9.4.2.
May I ask how to resize the editor? I am using macOS 13.4.1 and Vensim PLE 9.4.2.Administrator wrote: ↑Wed Jun 28, 2023 5:39 pm Also, what version of MacOS are you running?
The same way you resize any window, move the mouse over one of the corners, click and drag.
it works! thank you so muchAdministrator wrote: ↑Wed Jun 28, 2023 6:52 pm The same way you resize any window, move the mouse over one of the corners, click and drag.
