BUG? Control-<number> not select analysis tool
Travis
Post by Travis »
In prior versions of Vensim, there have been the keyboard shortcuts to select sketch tools or analysis tools.
Sketch tools are 1,2,3,4,...q,w,e,...
and analysis tools were control-1,2,3,4,...,q,w,e,...
I can select sketch tools with shortcuts still (though less consistently than before) but I can't select analysis tools. Is this a bug when the toolbars got written?
Re: BUG? Control-<number> not select analysis tool
Sounds like a bug, because it's still working on Win10 (assuming you're using a Mac).
Travis
Post by Travis »
Yes, I'm on macOS.
Kinda related, but did custom Sketch Toolbars go away in the New UI? I only see Analysis Toolset in the Tools menu.
Travis
Post by Travis »
Any confirmation that you see this issue on macOS?
I'll try and add it in. Programming for MacOS is proving to be quite a challenge at the moment.
