how can show the graph result as percent?
Percent
Re: Percent
You haven't provided much information, so I'll guess.
Assuming you have a value that ranges between 0-1, create a new variable and plot that.
some variable = 0.5
some variable percent = 0.5 * 100
some variable = 0.5
Re: Percent
Let me tell you what I mean with an example.
Here we have a graph that shows the ceiling of 10 million.
I want Vensim to show it as a percentage as display 10 million in 100%
- IMG_20231212_155600.jpg (54.53 KiB) Viewed 5148 times
Re: Percent
If the endpoint is fixed, you can use the approach of creating a variable.
If the endpoint is uncertain, specifically, not known at the start of the run, there isn't really a way to do this, except by postprocessing the output in some other tool (Excel, R, Python ...)
