Units tips or laws
Nub_User
Vensim version: PLE+
Units tips or laws
Post by Nub_User »
Hi, one general query.
Is there any compilation of laws or best practices for assigning or using units? I mean, which units should be used for each type of variable according to the functions assigned to them, especially when functions are complex or nested.
For examples:
- Use these units and format for flow variables.
- Use these units format for stock variables.
- For auxiliary variables employing functions like DELAY, INTEGER, IF THEN ELSE, PULSE TRAIN, etc., it is recommended to use these units or type of unit.
- Tips for ensuring coherence between equations, etc.
When one is a novice or intermediate and has to develop large models, inconsistencies in units, even when being meticulous and studying their assignment, are often numerous. :roll:
Thank you very much. :mrgreen:
Re: Units tips or laws
Units should be (and are) easy. If you have a level and you have cars in it, the unit should be "cars". If you have people in a population variable, the unit should be "people". If you have a rate such as birth rate, it should be people/year (or per month etc).
A delay should have the same units as what you are delaying, so if it's a birth rate (people/year), the delay of this should also be people/year.
When you put something on a sketch, think about what it is calculating, and that's the correct unit to use.
Are you struggling with something?
There are at least two rules:
- a flow has the same units as the stock it connects to, divided by the time unit
- EXP, LN, and a number of other functions require dimensionless units
beyond that, if you have
y = a / b
the units follow
y units = a units/b units
One consequence of this is that you can't add dissimilar units.
Nub_User
Post by Nub_User »
Thank you!
For example:
I have one stock variable with dmnl units.
For Inflow and Outflow I understand that the units should be dmnl/time (dmnl/hour or dmnl/day, etc.)
But when I postulate this in VENSIM, and I apply the units verification tool, VENSIM indicate to me that the units in left and right did not match.
Can you upload the model?
Nub_User
Post by Nub_User »
Uploaded.
Thank you
error_units.mdl
(1.77 KiB) Downloaded 66 times
Your flows are dimensioned dmnl/hour, but your time unit in Model>Settings is Mes.
Nub_User
Post by Nub_User »
Thank you very much. :)
