Forum Suggestions
This forum is for any announcements or any general queries.
Moderator: Administrator
Locked
RutgerMooy
Forum Suggestions
Post by RutgerMooy »
Can you remove the 'Mood' information? I don't think anyone is really using it. It's just cluttering up the member information box.
[Edited on 1-6-2004 by RutgerMooy]
RutgerMooy
Hmm... HTML does not seem to work in the post above.
RutgerMooy
So my second suggestion would be:
add the possibility to use simple HTML tags.
I will see if I can find an upgrade to the forum software.
ESC
Emoticons
Post by ESC »
Are the emoticons really working? One can click at them and the code is diplayed just like in other Inet forums but when the message is posted it displays with the emoticon code instead of the emoticon itself :(
:D
I'll see if there is a setting somewhere that enables them. They should be on.
I cannot find any settings.
There is an updated version of the software available, I will test that at somepoint over the next few days.
Locked
