Shadow variables disappear
I built a model wit a shadow variable and a lookup. Both nodes became invisible (they are still in the model). How do I make them reappear?
Go to Models>Settings and on the Sketch tab make sure that show lookups is marked.
Try edit>Select All then click on the first color button (usually this shows as a black button) along the bottom toolbar and set everything to the default color - or another color.
If neither of those works the sketch must have been damaged somehow. You will need to bring the variable back to a view with the shadow variable tool -In PLE to make it a real variable you will need to delete the variable and then add it again.
