I've got the following need. I need to visually high-light certain points on a time series (end-of-quarter, end-of-year) on the charts produced in Vensim for both external and model-generated time series. This is because certain business behaviors can change around points, producing many behaviors of concern. I don't readily see how to do this in the software from reading the manuals. Can anyone help me out with this?
Identify Time Series Points on Charts
I think I need to clarify my question. I'm wanting to know how to highlight on a Vensim chart certain points in time that are of special interest. For example, is it possible to make certain points in time a different color (such as quarter-end, year-end) on a time series chart where the behaviors of interest may be different? Or, would it be possible to flag these "milestones" of time with bars in addition to the behavior lines? I know, this is sounding more like an Excel charting function, but if I could display these key points in time in Vensim, it would be easier to show how behaviors can change relative to these milestones due to "quarter-end" or "year-end" informal policies. I'm thinking this is especially relevant where an external, historical time series is being displayed in a chart along with simulation output of the same variable.
You can use :X-DIV value=label in the graph definitions as described in Chapter 15 of the reference manual (requires Vensim Pro) to add legend lines with labels.
You can create different colors by using Dots only and defining a variable to be :NA: except at the time points you want eg
Year end employees = IF THEN ELSE(MODULO(Time,One year)=0,employees,:NA:)
However, what is typically easiest is just to export the graph to PowerPoint and add some annotation.
