When I put a subscripted variable in a custom table, it does not display anything.
Essentially, I have 5 companies with different values for a particular variable. When I try to put this variable in a custom table, it does not display any values
Also, is it possible to export to MS-Excel just a table's values instead of the entire dataset?
Malli
Displaying tables with subscripted elements
You need to put the name is as
variable[subscript]
where subscript is either a specific element - if you want to see only that one element - or a range is you want to see the range for all the selected elements.
To put this into the clipboard just use Edit>Copy (or click on the scissors icon) then Edit>Paste in Excel.
variable[subscript]
