Vensim equivalent function for Dynamo's CLIP
malli
Post by malli »
Am reading Tarek Hamid's Software Project Dynamics. While the models are described in DYNAMO and I had no problems in understanding most of the functions -
I could not make out what would be the vensim equivalent of dynamo's CLIP (A, B, C, D) . Essentially - there are always 4 vars inside the CLIP function - but what exactly does it do and what is the Vensim equivalent?
Malli
I know nothing about Dynamo, but I found a description of the CLIP macro at the following location
http://www.scs.org/getDoc.cfm?id=1947
Look on pages 2 and 4.
CLIP(PQRS)=P if is R> or =S;
If is P=1, and Q=0 then CLIP(1,0,R,S) = 1;
CLIP(PQRS)=Q if is R<S;
If is P=1, and Q=0 than CLIP(1,0,R,S) = 0;
My best guess at implementing this as a Vensim macro would be
:MACRO: CLIP(P,Q,R,S)
CLIP = if then else ( R >= S , P , Q )
~ dmnl
:END OF MACRO:
Remember that this is a guess, maybe someone else who actually used Dynamo can give a better answer.
malli
Post by malli »
Thanks Tony. That conceptually makes sense. I will check this with the text.
Malli
CLIP was also called FIFZ - First if First Zro so that CLIP(a,b,c) = IF THEN ELSE(a = 0,b,c)
