I have an Excel data set that looks like this:
year unit variable1 variable2 variable3 variable4 ...
1990 A 1 2 6 9
1990 B 7 13 12 4
1990 C 1 5 8 0
1991 A 1 2 6 9
1991 B 7 13 12 4
1991 C 1 5 8 0
1992 A 1 2 6 9
1992 B 7 13 12 4
1992 C 1 5 8 0
Note the values are not repeated, they are just examples. The years go from 1990 to 2006, there are 87 units and 4 variables.
Can someone suggest the best way to lay this out in Excel and and the code to use for GET XLS DATA?
Thanks.
3d input from Excel
The simplest layout would be
Time 1990 1991
var1[a] 1 1
var1 3 4
var2[a] 5 7
and so on. Then you can either use GET XLS DATA or Model>Import Dataset to bring the values into Vensim without difficulty. Note that instead of var1[a] you could have var1 in only cell and a in the next. For GET XLS DATA the labeling does not matter anyway but it does when importing.
Time 1990 1991
var1[a] 1 1
var1 3 4
var2[a] 5 7
