Custom Graph with multiple X-axis Variables?
Schepers
Post by Schepers »
I would like to show a vector field in a custom graph, with multiple X, Y traces.
The custom graphs allow to use only one single variable for the X-axis... (edited directly in the text editor, vensim uses only the last X-axis variable defined as the definitive (but onlu) ope.
Any suggestions?
Hans
Vensim graphs will only support a single x-axis. You might be able to work around this with some transformation of the X variables so they all made sense on the single axis - alternatively you may want to export the raw data to a text format and do the graphing with another package.
