vensim link matlab
Thank you bob,
I could solve it.but now I have 2 questions.
when I link vensim and excel, I use another excel file for my variable in vensim and in vensim I used it's adress, now I want to close automatically the data excel window after run micro and run vensim.what can I do?
another question:when I use for loop in micro to run vensim several times,after each run vensim ask me a question and I have to answer it to go to the next step Otherwise it will not go to the next stage.I dont want to see this window.what Can I do?
it's question:dataset current already exist. do you want to overwrite it?
This is all in Matlab code isn't it? You will need to ask on a Matlab forum for the answer.
There is a function you can call in the same way as vensim_command called vensim_be_quiet. Call this in your code and the box will not appear. But see the next answer as well before you do this.
What is the command you are using to run the model? Is it "MENU>RUN|"? If it is, try "MENU>RUN|o" instead.
[Edited on 27-10-2010 by Administrator]
now I have another question:
when I run micro, when it reach to the step that should show the result in the place that I specified for it in excel,for some of them this apears:--
But only somtimes.Do you know what is the reason??
[Edited on 10-28-2010 by ahmadi2010]
[The extension ocx has been deactivated and can no longer be displayed.]
after run micro,vensim has calculated and I can see the results in vensim but in excel I can't see it????
Sub GetValue()
Dim returnList As Variant
For i = 1 To 10
varstr$ = Cells(5,
.Text + "@" + Str(i)
returnList = Application.DDERequest(DDE_channel, varstr$)
Cells(4 + i, 10).Value = returnList(LBound(returnList))
Cells(4 + i, 9).Value = i
Next
varstr$ = Cells(5, 12).Text
Cells(5, 13).Value = returnList(LBound(returnList))
varstr$ = Cells(5, 15).Text + "@" + Cells(5, 16).Text
Cells(5, 17).Value = returnList(LBound(returnList))
End Sub
for the first time after run I can see all the value that calculated by the vensim, but for the second and ....... that sign apears!!!!
Sub GetValue()
For i = 1 To 10
varstr$ = Cells(5,
Next
End Sub
You will need to upload the model and spreadsheet for us to take a proper look. If you would prefer to email them to me direct I can take a look (tony@vensim.com).
I'm faced with a new event. I'm using micro like these:
sub load model()
end sub
sub setconstant()
endsub
sub simulate()
end
and so
when I run these micro by click on eachone steb by step,it works correctly.But when I record these micros and use one micro for running the program, I see (--) for some variable!!!!!!!!!!!!But I need to record and use one micro:(
sub load model()
end sub
sub setconstant()
endsub
sub simulate()
end
and so
You know you can call Vensim DSS by providing it with a .cmd script as an argument and have it do whatever you want, including exporting results to a txt file that Excel can read or pushing them to a database using ODBC that excel can also read. At the end of that a MENU>EXIT will cause the Vensim DSS process to exist and then you can start it again fresh the next time it is needed.
Re:
ahmadi2010 wrote:Finaly I could load vendll32.
Now I load this model:
str=['SPECIAL>LOADMODEL|',test,'.vpm'];
lp=libpointer('voidPtr',[int8(str) 0]);
calllib('vendll32','vensim_command',lp);
How can I see the result of my model in matlab or the amount of variable thet I defined in vensim?
You mean by installing XP, you solved the problem?
Re: vensim link matlab
This thread is six years old, and all the software involved has changed - I think you're unlikely to get useful answers here. I'd suggest composing a new question.
