This question have also a more complicated version:
If TypeValue has two dimensions (TypeValue[Type,Type]) and ObjectValue also have two dimensions (ObjectValue[Object,Object]), could I still manage to fill up ObjectValue[Object,Object] with values from TypeValue[Type,Type] based on the index in ObjectType[object]?
Model attached (db2.mdl)
Having downloaded your model I am not sure what you are trying to do here. See the model I attached to my reply in your other subscript thread, you should be able to modify it to handle this more complex situation.
