The concept 'simulator' is often used in modern SD literatures; however, to my knowledge, the definition of this concept has never been addressed therein. Therefore, I have two queries in need of your helps:
1) How is simulator defined under the SD tradition?
Below is a definition offered by non-system dynamicist Larry Sutton:
Simulator is defined as a device that enables the operator to represent or
reproduce under test conditions phenomena likely to occur in actual performance-
-Larry Sutton, National Interagency Fire Center
By this definition, it is still difficult to make a distinction between a
simulator and a simulation model.
2) For developing a simulator, which edition of Vensim should I apply?
Thank you very much.
Monte
Simulator definition
There is no big distinction - from the perspective of a use a simulator is something they open and use and they are not likely to make any distinction between a model and whatever interface the model is presented in.
Chapter 12 of the User's Guide describes the development of simple model interfaces and this works very well in a variety of circumstances. All of this can be done with Vensim PLE.
