I have a strange problem when trying to install Vensim 5.6a (I need this version for testing the compatibility of an external DDL). The installation process aborts with the following message:
"Failed to extract file vensim.ini+S"
The problem is strange as we have already installed Vensim 5.6a on another computer using the same files without any problem. I have downloaded again the files from the Vensim site in case the original ones were corrupted, but this was not the case.
Has anyone had the same problem? Can you help me to solve it?
Thanks in advance
Davide
