marvo
Posts: 4 Joined: Fri May 11, 2007 6:43 am
Post
by marvo » Fri May 11, 2007 6:50 am
When I try to compile my model, I get an error message saying:
"Failed to compile. (version mismatch got 509 need 508)"
What is version is Vensim referring to? Any thoughts on how I might fix this? Using Vensim 5.5d and Visual C++ 2005 Express.
Posts: 1107 Joined: Wed Mar 12, 2003 2:46 pm
Post
by bob@vensim.com » Fri May 11, 2007 9:56 am
It sounds like you have support files for compiling that are newer than the version of Vensim you are running. The best thing to do would be install 5.6d and use that. Otherwise reinstall 5.5d with the matching support files and it should work.
marvo
Post
by marvo » Wed May 16, 2007 7:48 am
I installed version 5.6d and things seems to work now. Compilation makes a HUGE difference in simulation time. Thanks for the help!
