gk720421
Posts: 16 Joined: Fri Jul 13, 2007 7:52 am
Post
by gk720421 » Mon Jul 16, 2007 9:04 am
How sould I do when the final number's decimal point
Such as 5 ,5.5 , 5.58 or 5.586
Posts: 4590 Joined: Wed Mar 05, 2003 3:10 am
Post
by Administrator » Mon Jul 16, 2007 10:36 am
Go to Tools->Options then select "Settings". There is a checkbox near the bottom for "Use European number format for displayed output".
Hope this helps.
gk720421
Post
by gk720421 » Tue Jul 17, 2007 2:38 am
thanks!
gk720421
Post
by gk720421 » Tue Jul 17, 2007 8:39 am
How could I select in vensim to do "523"------>"523.00" or "452.293"---->"452.29"
thanks
gk720421
Post
by gk720421 » Tue Jul 17, 2007 8:50 am
I find that
It show that if answer should be "5.281"---turn -->"5,281" I assume answer is 5281 ,not 5.28
how can I improve?
thanks.
Post
by Administrator » Tue Jul 17, 2007 9:02 am
If you are using European number formatting, 5.2 will show as 5,2. The number is still the same (5.2 = 5,2).
Post
by Administrator » Tue Jul 17, 2007 9:04 am
Originally posted by gk720421
I find that
how can I improve?
thanks.
Are you using the table tool? If yes, right click on the table tool and you can see some options. Experiment a little with "number format" and see if it does what you need.
All the best,
gk720421
Post
by gk720421 » Wed Jul 18, 2007 12:26 pm
thank you very much!
