Data save and import
Posted: Tue Jan 29, 2008 11:58 am
by mruud
On a daily basis I use a large model which is driven by external data. To run the model with the complete external data set takes a lot of time. The only change from day to day is an extension of the data set with data from the last 24-hour period.
Are there any smart way to save all values, not only constants, at the end of the simulation run today, so that I tomorrow can load this values for the complete model and run the model with just the last 24-hour period data?
Posted: Tue Jan 29, 2008 12:55 pm
by bob@vensim.com
Simply use the resume option in the changes tab of the simulation control dialog. Then update final time, then simulate. Note that the model needs to be a .vmf model and you will need to adopt a sensible naming conventions for the daily simulations.
Posted: Thu Jan 31, 2008 1:52 pm
by mruud
Perfect. Just what i needed. Thank you.
