I used Optimization for several times, and always it worked. Now I get the message:
No optimization, not creating optimize output file
The final payoff is -0.0318305
What I'm doing wrong?
Peter
Optimization
Optimization Parameters
Oh yes, this morning I played around with the optimizer and multiple restart parameters as I have noted that in earlier trials they were set otherwise.
Now as I have chosen Powell and multiple restarts on it is working. Thank you.
Is it possible that with 5.7 the default parameters have slightly changed?
The model isn't exciting. And to be honest: I found the best parameters a and b manually. Optimization only confirms my findings. This is also a worth information.
Peter
Peter
- test.mdl
- (1.44 KiB) Downloaded 341 times
Peter Addor
