I have a simple question to the "sample if true" function.
I have a function f that is small almost everywhere but has a big peak at time T, say f = 100 for time=T and else 0.1. So I want to cut the small noise such that only the peak will remain. I thought that I can do this with e.g.
only_peak = sample if true ( f<1, f , 0)
But this only cuts the noise before the peak while after the peak only_peak is a little bit biger than 1. If I select
only_peak = sample if true ( f<2, f , 0)
then only_peak is a littele bit biger than 2 after the peak, and so on.
How can I reach my goal, and why does the condition in the first argument of sample if true impacts the outcome after the condition has fullfilled?
Peter
sample if true
Yes, sounds logically and simple.
My original problem was more complex, and I hoped to use sample if true. But as usual the question becomes trivial if I take it out of the context.
(originally I tried to (almost) deplete a stock say three times serially first if it achieved level a, then if it achieved level b<a and so on; the inflow may be constant, but 0 as long the outflow isn't 0. But this problem hasn't to do with sample if true and so doesn't belong to this thread).)
Peter Addor
