hi all
I am doing rainfall-runoff model very simple. I just need a hand on one issue. I have some paramter as level with initial value. I need the model read the initial vlaues at time step zero but start the calculation for all other variables at time step 1.
Any help how i can do this.
Rainfall tunoff model
rainfall model
Hi Amgad
Your question is not very clear.
First a parameter cannot be a level, but eventually the starting value of the level.
Secondly, if the auxiliary variables are or are not calculated does not make any difference, as long as their value is only depending from the value of the past level. I think that you may want to keep the value of the levels unchanged until a defined moment, in this case time 1.
In that case, you have to zero all the rates if the time is less than 1. It can be easily programmed:
Rate = if then else (Time < 1,0,normal value)
What is the time step of your model?
You can eventually post a simplified model illustrating your problem.
