Botton Axis in Graph
Moderator: Administrator
CarlosF
Post by CarlosF »
My model runs from 2000 thru 2015 but I would like to show only from 2003 forward. I uncheck Automatic axis option on advanced1 settings and set initial value to 2003. The graph behind shows the change, but when I press close the change is lost.
What can I do?
I cannot recreate the error here.
If you uncheck "Auto Axes" and then click the "Settings" button, now select the "Axes" tab and change the minimum for the bottom axis. Does that work for you?
CarlosF
Post by CarlosF »
:P
Yes. It's working very well!
Thank You,
Carlos
