Dears
As I was doing previously I was using the control panel to set a basic graph to my model with the following scale:
In time axis:
Start time: 0
Special Time: 30
End Time: 30
Then I ran the model and clicked on graph button and the line is showed.
In order to display the range of years correctly, as I did it before, I have set the following:
Start time: 2000
Special Time: 2030
End Time: 2030
Then I ran the model and clicked on graph button but at this time the graph-line was not showed in the screen!
Afterward I started to set new graphs with several variables; however the strange problem still remained...
Basically when I have set the X-min and X-max as 0 and 30, the graph (lines) is shown but when the X-min and X-max was respectively settled as 2000 and 2030 with the X-divisions box empty or settled 30 the graph-line is not shown in the screen.
Somebody could give a clue what is happening, please?
Tks
Cláudio
