I'm interested in adding some super-macros to my model. That is, I would like to create a button (likely a Comment) that changes some parameters, runs the model, repeats, and then loads each new vdf file.
Put another way, I'm interested in generating two additional runs as a very limited sensitivity test. I would like the Run toolbar button to be the median run and then this script to generate "Hi" and "Low" runs.
I just discovered command scripts. Before I start down this path, I was wondering if this is the easiest way.
1. Are command scripts the correct path for implementing?
2. Can I use a comment or other button to launch one to operate on the open model?
3. Will this work in SyntheSim?
4. Pitfalls that I should be worried about?
TIA,
Travis
Button to launch command scripts?
You can use command scripts to do what you want but the path may be somewhat nonlinear. Command scripts do not work in SyntheSim - or during simulation setup. So what you would need to do is
Set up and create a simulation.
Set up a command script to read the settings for that simulation (SIMULATE>READRUNCHG) change additional things with SIMULATE>SETVAL, then simulate the run.
An alternative approach to this is to add another subscript for sensitivity to all variables
sensitivity : base,low,high
then you can look at the three together in one run - and this will work in SyntheSim.
