Dear Sir,
Our filesystem have the "&" character into filenames and folder names. When I try to open a model calling vensim_command from my C++ application and the model name or the folder name has the "&" character, vensim does not find the model to open. But when I open the model via model reader application, navigating between folders, there is no problem to open it.
My calling function is:
vensim_command("SPECIAL>LOADMODEL|c:\vensim\Projects\prueba&veras\empty.vpm")
Thank you
Jose Fornes
& character into filename and pathname
The & is used to separate Vensim commands. So Vensim is getting two command
and
veras\\empty.vpm
the second one does not make any sense but it fails on the first anyway so it never gets there.
There is not an escape sequence for & - I will take a look to see if one can be added.
and
veras\\empty.vpm
