I am trying to implement auto-calibration within Vensim. I have observed data in vensim environment. My intension is to make the calibration parameter (in this case calibration parameter is "width" and I am trying to match my "stock" with "observed”) time dependent. I looked at the Vensim Manual under Optimization section but was not able to succeed in my experiment. Can anybody please help me to resolve this issue? Please, have a look at the attachment.
Autocalibration
Autocalibration
- AutoCalibration.zip
- (3.44 KiB) Downloaded 816 times
There are several ways to make parameters time dependent, depending on the complexity desired. For example:
1. use the VECTOR LOOKUP function (see Help) to specify an array of points over time
2. write a time-dependent function, like p = p0 + p1*time + p2*time^2
3. rewrite your decision as a feedback control rule, with a few parameters
For most models, 3 is the best approach, though if you're just trying to fit data, it may not make sense.
