Hi all.
I installed VensimPLE for Mac, and I'm very happy, it is a great product. I have a simple question, is there a way to have two models (windows) open at the same time? In Windows I know that I can launch another instance of the product, but that does not seem to work in the Mac.
Is this possible on Mac? Any ideas?
Thanks in advance for your help
VensimPLE for Mac - open two models at the same time
- Newbie
Re: VensimPLE for Mac - open two models at the same time
I don't believe there is a way.
You could try installing to a different directory and then running the 2nd copy.
You can open multiple instances of an app in OSx via the Terminal window:
Go to Applications->Utilities-Terminal: type in the following command "open -n "path/to/file.extension"
You can also create a macro for Vensim using Automator:
http://lifehacker.com/5668648/automate- ... g-required
