Dear Administrator (Tony? - a name is so much more personal
I agree with making structure explicit and may thus use hiding to 'unclutter' model structure. Nonetheless in this special case the structure is only a work around the false display...
While 'playing' with string vars I noted really strange things in Vensim DSS 6.0.0.1 - maybe you should check this:
1. Starting a new model with a variable in the current view (not entering an equation) and then choosing 'new view' from the menu will cause the view counter to increase
still showing the variable from the first view. What is even stranger is that I can not enter an equation using the equation sketch tool. The variable simply cannot be selected with the equation tool.
2. I tried to enter string variables as filename and tabname for a data variable. Here I chose to enter the filename in the text editor:
While entering the variable
tabname as a string variable in the sketch editor. Now, entering a new variable
data in the sketch editor and then using the equation editor to make it a data equation with GET XLS DATA
the equation editor will not show the string variables as an input option (even when chosing 'ALL' in the drop down menu) in the variable windows unless one has previously connected them using arrows. I think that should be changed and string vars should be added to the dropdown menu for the type of variable to be shown.
Kind regards,
Guido
