Are there any examples of a "live" hotlink with Excel (as mentioned in the help)...using WM_DDE_REQUEST and WM_DDE_ADVISE commands? The DDE example files are "manual" in that you have to use buttons in Excel to stimulate the data transfer, run the simulation, etc. I want to be in Vensim and have an array exported to Excel at every SAVEPER automatically.
Hotlink Example
Re: Hotlink Example
If you want to export to Excel every time step, you will need to write an external function. There are some helper functions for you to do this, see http://www.vensim.com/documentation/ind ... ?25885.htm.
The other alternative is to run the simulation from Excel using the Vensim DLL. This way you can step forward one time step at a time and read the values you need via the DLL functions (vensim_get_data etc).
Both methods will require you to write some code though (or at least modify the existing examples).
